masho95
got Zex?
Ok recently I've been having a problem with my SHO. I only seem to experience the problem when the car is cold and it first starts up. If you start the car cold and try to take off in first, there is VERY little power. It seems to just bog then finally will get going. I've only noticed it at part throttle and I'm not sure if it does it at WOT (don't think it does). Does it in 1st gear and 2nd gear. As soon as the car warms up a little it acts completely normal.
I showed the problem to one of our mechanics at work and he seemed to think it was ignition related (like a misfire). The car has new Motorcraft wires and brand new Autolite 3923 plugs (nitrous). I made two very short 3rd gear nitrous injections on the new plugs but haven't had time to look at the plugs. Our mechanic suggested replacing one plug at a time to find if it's just one bad one. (easy for the fronts
I was thinking it was a bad sensor that's only used at startup with a cold engine (is that closed or open loop?) I know it's time for a new MAF, the one in there is slightly bow'ed out from the backfire I had a little while ago (see Emergency Issues post I made a little while ago). Also there is one wire that is slightly bent. So I'll have to look into replacing that sometime soon.
So anyone have any ideas?
