hammer5312
I have a 94 ATX which has the following problem; “stutters” at part throttle, under load; seems very prevalent under load, has poor fuel economy (14mpg), has poor acceleration, Demonstrated loss of power from 1500 to 3500 rpm, When driving at part throttle, the 1 – 2 shift car feels like the front end is dropping into a hole although not as bad since changing TPS, stutter does not happen with car in neutral or park.
7/18/05
Car to Mel Hambelton Ford "Wichita,KS" Performed Computer Diagnostic (was told car had good Fuel pressure & Good Spark) {Cost $371.00 to R&R EGR Sensor
} They thought possibly the MAF was Bad?
7/23/05
Purchased Salvage MAF from 5spd car (Installed – No Difference)
7/24/05
Purchased Remanufactured MAF from Advance Auto Parts (Installed – No Difference)
8/8/05 Gas Fill-up 13 gal @ 196 mi **14mi/gal}
8/9/05
Went back to dealer to discuss problem and the feeling is not a warm fuzzy, essentially they want nothing more to do with the car unless I am willing to throw obscene amounts of money their way!
8/16/05
Went to Private Repair shop after listening to Fuel Injectors which sounded okay, suggested replacing O2 sensors (purchased 8/18/05, installed 8/19/05) – Thought it made a difference, but there was No Difference
8/23/05
After talking to SHO Shop I Performed diagnostic w/ code reader – No Codes,
Ran cylinder balance test four times (code results “9” – All okay),
Tried disconnecting MAF plug; condition worsened, reattached MAF plug
Have suggestion of checking coil pack, plug wires, spark plugs "I Have not done this yet"
8/30/05
R& R Throttle position sensor - Slight difference but still running very rich and had trouble starting when hot.
The car seems to be running very rich and feels thready in the forementioned RPM range. I have tried about everything I can think of short of using a thermonuclear device. I welcome any suggestions, I even have a CD manual but have yet to find any answers on it.
7/18/05
} They thought possibly the MAF was Bad?7/23/05
7/24/05
8/9/05
8/16/05
8/23/05
8/30/05
