Struts yes...but springs ?
Kevin
Winsted,CT
I need struts real bad in this freaking 91 but I got it for cheap so...I will put in Tokico struts but am hesitant to put in Eibach springs because I don't want problems with the alignment nor do I want to mess w/ the brake bias. It seems both issues have come up when the above mentioned setup is discussed. If I put the performance struts in w/out the springs, will I be able to deal w/the car as if it were stock? Am I wrong in thinking that things become difficult when the Eibach springs are installed e.g. can the car still be treated as "stock" with the spring & strut set up?
WaterRooster
Here
Get springs. Struts can only do so much, but if your springs are bad....you get the idea. Let me suggest the Intrax Sping buy in that Nook is having. 169$ for a pair of intrax springs!!!
Shawn
93 Emerald Green MTX
PP Y-pipe, Dynomax Catback, 80mm MAF, LPM, Ebachs and Tokis,CAI
Kevin, try prosuspension.com for spring group buy. He also is selling sfc's for $89 includes shipping.
gpwebman
Stoneham, Mass
Having used the Eibach springs and Tokico struts on my '95 SHO, I can tell you that they do work together very well, and there were no problems with the brake bias. The car needed to be re-aligned, but no problems there either.
Check the buy/sell posts if you're interested in strut tower braces
'01 Ranger XLT 4x4 4L V6 5-speed
'95 SHO Auto
