Strut tower brace
T
Tommy the Greek
Guest
Hello Everyone,
Quick question, will SHOSHOP's strut tower braces Front and rear fit from a '91 SHO onto my '95 SHO?
Thanks
'95 SHO ATX, 55W foglights, coneless, fishtank mod, white/mocha cloth interior, 47K, Mobil 1 10W-30, build date 12/13/94. 60K service performed on 12/21/01 @ 46,043 miles due to a leaking w-pump. (grrrr)
Below is a pic of her @ 37K miles (July 2001), overlooking the Long Island sound off Orient point, NY.
www.roushind.com
AIM: kalamos73
89 Gary
Millbury, Ma.
You could call the bastard -oops,did I say that? and he'll let you know. I do know of course that they are somewhat adjustable for length so? good luck Tommy
RStalveyARFF
too many shos
Georgetown, MA
The front should fit no problem, it's the rear that may not fit. If you have the JBL system in your 95, with the subwoofer, than you may be up Sh*t creek, otherwise, it should fit fine.
P
Prophet78
Guest
If it doesn't fit, I will buy the rear!
-Jeremy-
E-Mail Address: mailto:p[email protected][email protected]</A>
Webpage: http://prophet780.tripod.com
'93 Red ATX "Red Phoenix"
Rebuilt "Ford Quality Rebuilt Transmission" w/ Shift Kit
Cobra ESD 9200 "Fuzz Buster"
SHOShop CAI W/K&N
SHOShop Front STB
190 LPH Fuel Pump
Koni Inserts
Eibach Springs
Blazer Modded Fog Lights
Taylor 8mm Spiro Wires
SHO Filler decals
Fish Tanks
225/50/16 BFG GeForce T/A KDWS
DeaconBlue
Cleveland, Ohio
The SHO Shop STB's are designed to fit both Gen I & II. You just have to make sure you get the correct rear brace. If you have the factory JBL sub woofer, then you need the bent brace. If you don't have the sub, you need the straight brace.
95 MTX
with a few mods
ManySHOs
South Jersey
Originally posted by Tommy the Greek:
Hello Everyone,
Thanks
Yes
Ian
FAST4DR
Here is a pic of the front brace from the SHO shop on my 95. I think it comes in gray. I painted mine to match my car.
William
batchman
backwoods MA
Does the front stb really do much for you? A two-point design, and already so close to the firewall, seems to me like it wouldn't be a big difference.
The rear would seem much more likely to be helpful as there isn't other structural metal nearby.
Curious,
- Jeff
viperrt450
Downers Grove, IL
The front one makes a huge difference. The car goes where you turn it. I didn't notice that much difference with the back one on.
95 ATX Green K&N Panel Air Filter, silencer removed, Blazer fog lamps, SHO lettering filled In, Tinted windows all around, Remote Start, Super Turbo DynoMax Mufflers, Home made front & rear strut tower braces and SFC's, 60K done by Performance+, Pionner CD Deck, Clarion 4x400 amp, Rockford Fosgate 800 watt Amp, 1 12In subs, SHOCAGO license plates.
94shoboy
south shore, mass, usa
the way the rear mounting bracket is made (L-shaped) there is too much play with everything so the rear doesn't do that much, you could do some work and see if you could weld some extra support to make it stronger.
FAST4DR
Wow, I thought they both made a big difference, especially the rear. I don't know about not strong enough on the rear. It is pretty solid. The car does not seem to twist as much. I guess if you only drive your car 7/10's you might not notice a lot but I think they are definately worth it.
William
SW SHO
Boss Man
Santa Fe, NM
Alright, do the hood shocks have to be removed once the Front STB's are installed?
Lance
92 Black MTX, 95K K&N, Stock but not for long !
DeaconBlue
Cleveland, Ohio
Yes, the hood struts must be removed. The SHO Shop ships you an aluminum hod prop rod as a means of holding up the hood.
95 MTX
with a few mods
