Strut Isolators?
Paul1990SHO
Canada
I got this info from other threads. Can anyone tell me if these will match moog sprins on motorcraft struts for 1990? The info suggests not. I would imagine however that they do since the strut and spring are the same through the years, just making sure, thanks!
I do have the right part right? This sits between the springs and the top of the struts?
Front p/n E8DZ-5414-A $6.99 EACH (need 2)
Rear p/n F1DZ-5K617-A $6.99 EACH (need 2)
Thanks a lot!
Ishodu
The parts should fit all replacements because they should be made to the same sizes as the stock ones.
I don't know if you got the right part #'s though
They fit between the bottom of the spring and the strut perch.
Paul1990SHO
Canada
You mean top of the spring right?
I think I found what I need but they are $16 instead... for some reason these parts come up under collision.
Ishodu
Strut mounts are what sit on the very top of a spring strut assembly and hold the spring on the strut. Strut isolators sit on the bottom between the bottom of the spring and the strut.
Paul1990SHO
Canada
Hi. I have a receipt in front of me from last summer. It is from Ford parts:
E8DZ 5414 A INSULATOR - FR
It is sitting on the top of the spring before the strut encloses it!
I guess this answers my question as that part went on the front of my 90 so F1DZ-5K617-A should fit the rear.
I am confused by your answer!
Thanks!
Paul1990SHO
Canada
I just realized I started 2 threads on this.
The cause of my confusion is probably because I meant INSULATOR not ISOLATOR :(
Sorry!
