On a 2011 ( 50k miles) I had a leaky drivers side headlight. I fixed the leak and replaced the ballast with one from Dorman. The light seemed all good so I put things back together and then it started flickering 3 times and would go out. When I happen to get lucky it it stays on but there is no particular pattern to it working. So after being followed home from work by a cop for what I'm only guessing would be a headlight out , I was thinking it was the ballast not being an OEM I ordered one and installed it. This one lights the light but will not turn off no matter the position of the switch.
When I first replaced the ballast a bunch of water poured out which fried the original ballast. Could the water have damaged something elsewhere as well? Passenger side works normally.
I'm totally frustrated and have no ideas on what else it could be.
Thanks for any help.
