i've recently gone on a few long road trips with my gen2 mtx sho.. after about 5 hours of straight driving at moderate speeds (holding maybe 2.5-3k rpm steady) the CE light turns on.
the temp guage holds steady below/mid normal throughout, but does sometimes float around in this range (doesent steadily rise or fall often, usually skips up or down then stays there for a while, as the tstat opens i assume)
when i get off the hughway and give the car a rest she is okay for a while longer.. checking the oil during these breaks it seems unusually hot, and the stereo head unit i've got installed gets really hot also.. rad is full and overflow bottle has some fluid in it also. just gave an oil change using 10w30. the outside temps during these trips have been well below freezing also fyi.
do you think the dummy guage is toast and giving me an inaccurate normal reading? should i just go in and replace the t-stat even though it seems to be working according to the way the dummy guage fluxuates?
thought i'd check in with y'all before i go and run codes. anyone seen this problem arise in the past?
