Stock Strut Chrome Rod Turning Blue
shotaurus
so. cal.
I finally replaced my original struts (May 1991 SHO with 56,000 original miles) I installed the Monroe Sensa-Trac , my question is that one of the front struts on the chrome shaft was blue a few inches up and about an inch on long the shaft , I have never taken this car to a track , the right rear dampening was totally gone , what would cause the blueing.
shotaurus
so. cal.
I agree but the fronts had **** , they worked OK , I guess they had **** in them , but the back lost dampenening and was not blue , I assumed they were low on oil or lost most of the oil.
Lightning
Alberta
generally speaking, heat will cause steel to change colour, blue being one of the colours.
if it was heat that caused the colour change, then that strut rod reached ~ 550 degrees...
HotRodKid
mmmmm ... turbo
Western NY
the strut is dead, the blue is because it lost **** and then the up / down motion it gets during driving heated the steel and blued it
replace it
shotaurus
so. cal.
Thanks agin for the info , all the old struts are in the trash , I was just curious about the blueing , I never knew that struts got that hot.
AREA 91
PA SHO SHOP
Area 91
Are you sure that your mileage is 56K and not 156K?
Exitwound
_McLovin_
Wisconsin
I can blue steel in my oven at the house and it doesn't get anywhere near 550 degrees. Stainless steel will blue around 375 - 400 degrees F.
