Stock Exhaust on G2
93 SHO Tuner
West Coast Canada
Is the stock exhaust on a G2 SHO from the cat back 2.25" mandrel bent Stainless steel?
My 94 has 2" piping from the flex pipe back which was put on by the last owner recently and it has the crush bends on the part of the piping that splits to the mufflers behind the rear axle.
I was going to get the 2 Mustang GT mufflers I have put on the back for $150 labour but after looking at the piping maybe its useless and I should just save up and get either a stock setup from the wrecker(if its 2.25") or have a custom system made and then put the GT mufflers on at that time.
If I go with saving up for a better system I could clamp on some cheap turbo mufflers for now and clamp them on myself(current mufflers are clamped on) for a throatier sound.
sperold
Last to Know
Your 94 should have a 2 1/4 piping system back to the y-split pipe which enlarges to 2 1/2 right at the Y, then each branch goes back to 2 1/4.
I don't know if it is stainless steel, but it lasts a lifetime.
You have the single exhaust system piping which is 2 inch, and someone has made a y-split pipe.
For now, do your clamp on turbo mufflers, and if you can find a JY SHO, the exhaust system will still be in good condition.
