There are quite a few members touching 550hp on the stock block without issue.
You can get a manley rotating assembly and ARP head studs for around $1700 on our website that we have several Ecoboost customers running with good results. With that the engine is theoretically good to 1000hp.
No closing the deck huh?
I always enjoy a good close decking conversation.
Theoretically, if you did build the motor into the 500+ whp range, couldn't you cryogenically treat the transmission's internals and add some more durability to it?
I've seen these motors go before and after upgraded turbos. I've also seen people make ~600awhp/torque on stock block. It's anybody guess how much we can handle.
I read somewhere that the connecting rods can only handle 500hp. Do forged internal exist for our platform and are they worth it?
Ideally I want to push for low 11s and if the tranny holds up into the 10sIt becomes a question of longevity and goals... you can crank the torque/hp up.. but how long will it last. Historically if you are running a good tune, regardless of turbo configuration, it appears under 500awhp seem to net good longevity.
That’s the pointYou should ping Jordan and 802SHO for what it takes to get to low 11’s... there are no 10 second ecoboost SHO’s.
That’s the point
