Stock block limitations
I know I'm 'that' guy that keeps beating this dead horse. But, if you want to run lower ETs then consider dropping weight in our 4500lb sedan. That's how Jordan got to where he is (fastest SHO currently). It's not all about HP. Plus, weight reduction means less stress on things like the trans, RDU, PTU, half shafts.. etc
I agree, weight reduction is key. However so is actual vehicle selection. There are tune only Mustangs going into the 11's full weight easily. Put a blower on them, and they go into the 10's, for less then a new priced SHO. Sometimes significantly less. They are just set up better. They have a better trans with the 10 speed. When can even debate which motor is better. The EB 3.5 or Coyote/Voodoo. However, a mustang gets lost in the crowd, when they park next to my SHO.
99% of SHO owners are not willing to strip anything out of our cars. We like the comfort and quiet. Personally I am always willing to make more power, then ever remotely thinking of removing weight out of my SHO.
There are the fringe owners like Jordan, Andrew, and yourself. You all have your place. Jordan and Andrew are pushing the platform more and more. However, there will be a point that with the current aftermarket, they will not be able to go any faster without continued reliability issues . I think that will be in the mid 10 second range. At the end of the day, you can buy something faster, more reliable, and lighter for a less then a new priced SHO.
We love our SHO's because they are unique, nice, and straight catch people off guard at a street light. However compared to other vehicles, we will hit a wall at a certain point.
One could even go so far as to argue the f150 3.5 is light-years better. Lol
Say what? A different platform with the correct engine and trans combo....turned the correct way? Come on meow.....
bpd1151
Lurking Around
SHOcago 'Burbs
So true. Both paragraphs above.
As far as WR goes, will I do SOME WR when my beast gets back up and running? Yes! To the extent that Jordan has? **** F'n NO! Hahahaha
I just couldn't ever stomach performing the amount of, or going to the extent he has, in the WR category.
But that said, he deserves kudos for undertaking it and subsequently capturing the top dog title of the EcoBoost SHO world. For now. Muahahaha .
And yes, the platform overall has always been unique. Niche. Mysterious and rarely known to most outside of the owner's and some enthusiasts being aware of them.
Which, despite its' respective challenges, is what drew me in, and keeps me in!
Ecoboost_xsport
Sacramento, CA
...then consider dropping weight in our 4500lb sedan.
And in my case, try closer to 5000lbs, LOL. Ive done quite a bit to lose weight for my application:
Lost about 110lbs with 3rd row delete:
y4m27w5XLIfyNAU9hUUlElfMBRPCBjP9M9m5OO-gLokgoG4JswqVq1SxZgflZt2L-8oSo_lI5wLBuc24hQ5rMEduu8dHdRjq_D5T3x_7cjjBKsyb2x4jhbSwdHYMnl_1kVKOWJb7ABtrFKpZcOVQEhozvZbxNhupHClCAj6WcsCeXrm-LVvTjeyVbxETRkTqj0rXgTJqA4F5Aa_ZxX6uxpU0Q
Almost 30lbs with Lithium Battery:
y4mYio7vp13hAEcmNr0W8XqtfsYFyqQzTDDS2u0-xbbTH-aahnzxFOEUgDcPBlM4A13nVMUFY1AUtBlKxJhv1Uuo0zXRq5hO39pHh1hK_jmDU2FvM_XBq579hMV2PBD7z836D_VNsGwFS5lS8LO8nTZlj_WruDpLLxl8ST_8REv7yT97x0WnbsIvjPiGHyttMTgL5NY0AO2Iik36xHlweJ9tw
About 48lbs on wheel/tire combo (12lbs per corner). This made a HUGE difference on how the car felt to drive. That rotating mass makes a big difference. I know it only looks like a small amount, but the rim itself only weighs 19lbs....it's the damn tire itself that was the weight adder here.
y4mdUppkNjsX1PNtXaRJ1c8rAXGzzKi9z8HAOyvly3z_99oGvZUySod4GowT1ut2UOBYhjY7zydm-0F-Vz13DzZyAVPKjRdTaf6DeLua3r5OEJFeI55vrElEjGsIc3mvaEPE-2vypsd1uiWh1eaA0zAjPKpPW5YWLNXr1_NV6DktO3Gv8-BHsTqIcUVRpvJG93VpokGeK9ES4V-j0sApIVE_A
y4mqgkuM54_jVSjTyTimrO65G4kzhJ6EFLu3XUN9jk0pzNcl2Wv15Im9-1ZzI8VOBv-lseq1b_JqXmu4ysxvefmOUixgB_0vb06Wky9ZOYmjUcL79Vhviizl3NUM6lJuLif2iaYuTPzfnljcSl0Fv57yOAyPtkhzZxCCDC7NNsMa9XEKwz83i6d-6Kxnri-v8Repg3T-egZI_X47l5G9Pieew
About 30lbs for the front brake conversion (15 per side)
y4m7fgzxEALRIdUlWJbA5YR6mk6KH11iy4IRoa2C9f3KvocPfoUAeIdiw7FbjfbhNydTwEdsiN7X66d_n5-YB7yB62_PRUv44oUvAg9fHgKgF1SXsBHQs2sMo6YWIqVhbubV_jReFfI5_26g15IbhFqk_NfhGLn9NTTFLHSpWjTvXdgfUobKTaGfhFvR9FZFKGYYGCp6unfI6LyXeEjfKL6Ew
y4mUChUztc_cpDCZYe_Wsx0GZn_ladHihK0HTKLrER5iwhYw_85rK5CHV71JXJuu6I6MYAADycW4h1v0A66XR95KzApe11nsTKuKHDUaxcFozMDJ5qdxv1KaVvEMUsTRlVHh86UxLM-fbl0WDO7J4MeGaseac8KCNGWM-ftwGCEG6zfKAmGit7C-SLa0oyIXfoqQCM4Zg4c474nDHOMXktrdw
y4mgnFTl--75PspXWAMrHzG-0BUyKxt9cIQNKBpRO2s8ACLhtDxGyfjDg9i3J0q1Meaeo59uz8jGPC3FcFP3BEaCzoC-vkyB4k8_ngC9tarPwC-b4-LacrWv7cfjBxiD9THNRwNf18D-Ibdk8UeOvjTLQJ33UMQT167avIo0dkK-tsuhmP7bRc09vEc0CiXYGOM7YAqvK5DrrztPYAReC3raA
About 8lbs for the rear brake conversion (4lbs per side):
y4mFhplyblgR2ndTgOnpmrP8uGvjLhuXtQGn3uInb7FYK33yi_HWUYjrsO6VFwcq0ElNJEy2UBJXLNCekjB0kz2bLjSkxJZU4StNzUyUpjf3XcbsF-aEj5733-cpR_Ep1L0Gum704dWOvAV7sSTpQ8zqbnlFR_6mmgDWuvLiDphCpAkCwwNXcvwykxD6RPeNdAMfZhqK2l-SZDZfhkBdu6frg
y4mHhN8F0FZUK1hccwvtXkS4SxSngMVyPf1u_7LsYLdxNItOn4NvR2MB-wtWzSJvXidArbD7gm8Bnaef1kiDwgPRBI7y5QviuvCr1gAXxYLRYAzDd0dkKF67sRe29828EwOHqeXsdJM_XG3oOUxAimVZ7q5uonPTAnYJRqgTq4iDKn0TTius36PC-X-oOiu6vZqxaHSSH4n7y0zg6y-dg-vug
y4mhLwF17fhFA9tGZETDgGxWgqBqw79smiL5yOiiDFUDFcN2NHivRaHcgofNWLK0tmRB-6QhUmlcFMFSYByBhQHsgRX-yPWAoQuXC3MAa0zfZ5UXuxV5s6XQRTg_aEkANuhPwj055KuQsNRqXA05wd3jiY_NVGpYW8AJr46osmuA4VC3OjaGupPEmaEVegKQOnyJL8MYZdVMhAVtA3WiJCkQw
Along with a few small things here and there (I'm sure I also added some with some of the aftermarket parts) brought me to a new whopping, featherweight...
y4mSDFySiRw5uFw-_JkhT73y0Q5oS1g7tcDbrhrOb2Y6qxY8wvmhDfOk_diztqv2zgNDQfBIka81iiTzvZywSNhacOVx4aOUc85chWdQLAe0OEy64DVynKeY1QCV-gybbivjEXNyjN61NxV5k96CILI-dKfFmJsmauXxlMC1fxp812XUtRpszBeY-vmsdipMU8qabulxc2Hk8736whwxZuQLA
y4m2IFsU9Tp7rnHQbga1IH_14HRnJSQk5MWV0ZLcrYj-u7XgOI4vsvQVmadUCAGa68cvBZ3dMSlIXrPZy5ZuMyFciRYIO8ECQai0arzIoWi9pmRRt759uCBxEO_8ywjzNHPnWNUQNNven7y6sirdGqeUMoXXyf7VlV1FIvRJms7XxWF3-zEpc4dYtEZNMCltuXwYv94RIDPclek4n2hzzhx0w
4541lbs!!!! haha...damn this thing is heavy, LOL. I didn't have the scales when I first got the truck...wish I did though, would've been more accurate.
...However, a mustang gets lost in the crowd, when they park next to my SHO.
And my platform is even more rarely modified. You know how many minds I blow simply having an Explorer with TE37s on it, lol...
skyshadow07
Oklahoma
Xsport, I need to follow your build. Looks like you're doing it right.
Iqoniq
Atlanta, GA
There's only so much weight you can take out before you pretty much eliminate modern conveniences. You could remove your back seat and passenger seat, and swap the driver seat for a racing bucket seat. You could replace the sunroof with a carbon panel, and strip the dash and entertainment system (assuming the car doesn't need that to handle functions). You could remove all the carpet and a lot of the interior panels. You could move to the outside at that point and fab a carbon/fiberglass set of fenders, a hood and trunk, and front and rear bumpers. And of course you're gonna be running a set of lighter wheels, too.
But at this point, I feel like you might as well get a stripped Evo or something. I guess if you had a Police Issue SHO you could feel a bit better about drastic weight reduction without destroying the interior of your car.
I would love to reduce weight, and eventually I want to experiment with fabbing fenders, trunk and hood, and bumpers. But I don't think I'd touch the interior of my car much ... I bought it because of the luxury element. And probably most of us did so.
So in the end, for most of us, it really will come back around to more ponies.
High on Ethanol
Just Ain't Care
USA
I was actually just thinking about the basics, factory cold air intake, great intercooler, better turbos, better fueling, variable intake and exhaust cams.....
Ecoboost_xsport
Sacramento, CA
LOL, thanks...I'm nowhere near where BPD is with his SHO, but not far behind. When I put the money down for the engine build, is when I first started really posting here after seeing he is pretty much doing exactly what I am for my platform (hmmm, or is it the other way around? Technically, he's first, so...LOL). I try posting on the explorer boards, but they are so dead...ugh...there's really not many of us and I might even dare to say I may be THE only explorer going the lengths I am going to...IDK.
Ecoboost_xsport
Sacramento, CA
Also ... that is a badass explorer.
Thank you...you're right about the lengths to go to reduce weight, but I am pretty mcuh done with anything major now...I pretty much trimmed all the fat I could without going crazy and losing that nice, open, plush SUV experience, lol...
I would def go the carbon fiber route if there was anybody doing that with some off-the-shelf parts, but I don't have it within me to go have some one off parts made...haha
Zpak
Es Aich Oh!
The region, Indiana
What is the Explorer 1/4 mile record?
