Cranks and cranks, tach moves and show rpms as starter turn over. Volts at coil drop to 7.76 volts when trying to start. The other wire going into the coil have very low volt, about .179 volts. There is no spark at all. Fuel pump works and there is pressure. None of the wire are broken that I have tested. Changed out different CID, no change. I had been doing about 150 mph(no speed limiter) on local road earler in day(x-mas day, no one on road for miles.) Car drove fine after I got off HWY. Leave my in-laws about 5 hours later and car bucked twice about 5 minutes after I left their house. Then about a minute down the road car shut off. I put the car back in gear to start the motor and it would not restart.
Now the LPM I have would cause the same problem after I would let it sit over night. It would crank and crank but no start. Pull the LPM out and it would start right away.
Sorry long.
Sorry long.
