Sticky gas float?
Spring Hill, FL
I fill it up, and I drive it around, it could be full it could be a half a tank, it only moves maybe under the line an 1/8 of an inch, then sometimes it'll go above the line the same amount, and when I park, I come back the next day and it's much lower than before, I guess that's my true fill. But sometimes it'll slowly go up about an 1/8 of a tank or 1/4 before it stops and starts reading the gas again. I can't tell if it's sticky or if the sending unit is bad, I don't think it's the sending unit from what I've read of other people's problems. Any help would be great, thanks!
shoteen95
isn't a teen :D
Dearborn Heights, MI
eh, i feel your pain. My gauge has just stopped working on E. The trip odo has become my new gas gauge. Good news though, i'm still getting about 20mpg around town and I'm hardly a featherweight with the gas pedal.
Spring Hill, FL
Hmm.. well, when my dad took it on a long trip he said it worked fine, went down as it should. So I assume it's probably that antislosh module then, he was on flat highway and it worked like it should. Is there anything I can do to make the module work again or is there a place I can get one?
