Stereo Woes
bc1025
Badge1025
Florida
When my JBL went out, it drove me crazy trying to figure out what was wrong. Eventually, I determined that my CD player was causing the problem (no sound). Simply dis-connecting the CD player still didn't allow the stereo to work. I was losing my mind because I like the factory look and impressive sound from the JBL's. After much thought, I caved.
IMG 0099 zps90145e24
I broke down and decided to upgrade. But, and I stress but, I wanted to retain my factory amps and speakers. I attempted to use the speaker harness that is supposed to by-pass the amps. It didn't work so I used this part and now can use all the factory components.
IMG 0130 zpsaaafe856
51DGLVsTx0L  AA160  zpscea2d302
The sound is incredible. I'm an old heavy metal, hair band lover and I don't need 6 sub woofers.
The stereo I chose was the DUAL XDVD from Walmart for $198.00. All I needed was the in-line adaptor and harness adaptor. The final look was impressive and all I had to do was cut the cross bar that separates the radio and CD player. I think it looks and sounds great. I hope this helps anyone on the fence about this topic.
IMG 0147 zpse260da6c
IMG 0150 zps7a32ce74
IMG 0152 zpsa556975d
BC
Let me know what you think. The hardest part was getting the trim out.
Looks like a worthwhile upgrade :thumb: May do something similar myself someday, what with the cassette player on the fritz.
pejohnson
Ohio
I'm trying to hook my aftermarket head unit up to my factory amps and speakers but have not had any luck thus far. I have got sound but is sounds horrible. What part are you referring to?
intimdatr
Got Cams?
Jefferson City, Missouri
I simply connected my head unit to stock wiring with an adapter to the head unit, got the adapter from wal mart. Works like a charm and sounds awesome!
bc1025
Badge1025
Florida
The Blue Thing in the 3rd picture:Scosche SLC4 Speaker Level Converter - $18.00 Walmart.
You simply screw the speakers out from the Stereo head (which should be already attached to the Metra Ford adaptor) to the 8 "in" slots on the top of the adaptor. Then you use the 8 "out" lower slots that go into the harness adaptor to the thick gray amp cable.
If you are trying to use a radio with an internal amp, it will interfere with the JBL amps and sound like ****.
If your unsure what I'm saying, let me know and I will post more detailed pictures.
BC
EL SHO
Taco Manager
Monterrey, Mexico
did you use any other trim adapter?
does it fit firmly? how were you able to make it fit in place and not move/slide out?
bc1025
Badge1025
Florida
No adapter, all I needed was the wire harness. Very snug, trim plate easy to take off then it slides out with harness keys that came with the radio
Fordlover96
Virginia
So, I dont if I missed anything but did you, bc1025, have to use adapter from the wiring harness to the radio? I only ask because Im about to do this wtih a JVC unit and am wondering if they even made an adapter for this car. Thanks.
