Steering Problem
1992SHOMTX
Vrrooommm...pssshhhh
Providence, RI
i have a problem with my steering on my 92. The wheel is turned 90* to the right and pulls to the right under heavy acceleration. It wasnt like this 5 hours ago and id like to fix it. What could be causing this? How can i fix it. Ive never dealt with steering problems so if you know how to fix it please tell me how to go about doing it because i could probably figure it out but help would be better..
Thank you in advance all help is appreciated
Chris
EMB2580
Mike is a L O S E R
Zion, Il
a car will usually pull to the side if your front end is out of alignment, did you hit an big bumps recently? that can screw up the alignment. also if you haven't checked the tires one or more could be low a low tier can cause a car to pull to the side (and **** your fuel economy) good luck!
1992SHOMTX
Providence, RI
no its not that kind of pull....it will drive straight under normal acceleration.. Once you go WOT it starts pulling even with your hand on the wheel keeping it straight. it only started happening out of the blue about 5-6 hours ago....this sucks..
EMB2580
Mike is a L O S E R
Zion, Il
hmm, well then I don't know what it could be either, myself I have a 90 that is having heating/cooling problems.
dstig1
Hudson, WI
If it happened that suddenly, clearly something broke. The question is what? Subframe mounts? Suspension bits? Steering bits? Get under there and look.
