After turning the steering wheel while the car is off, when the car is turned back on the sterring wheel is off centered but there is no problem with the alignment of the front wheels. Do you think I need a new rack?
sdpatt said:Did you remove the subframe during the engine swap? Moving the subframe will definitely affect the alignment (along with the upper strut mounts).
