intimdatr
Got Cams?
Can i get some ideas of what bad front strut mounts would do to the car turning? Im trying to decide if my rack is going out on me or if my Strut mounts are just shot and need to be replaced. Also would bad Strut rod bushings lead to this I doubt it but i thought i would ask)? Almost everything is new in the front end so im a pretty sure its either the Mounts or the Rack but seeing as one is 20$ vs 200$ i thought i would ask.
The feeling im getting is sometimes its like the front end is stuck or bunged up and doesnt want to turn right, but if i sorta muscle through it then it snaps really hard to the right and everything is back to normal. If i jack the front end of the car up and just turn the wheel freely i feel a few tights spots almost but nothing crazy for a 20 year old car. I would also like to point there is quite a bit of play in the steering wheel, maybe 2-3 inches of play, fairly sloppy. Its an odd feeling to describe when it does it. It appears to be induced by hard turns like turning around where its a full lock situation. Hopefully someone else has had this happen to them and can explain it better.
I havent had much time to try and get the situation to occur as its been raining non stop today (first time in since June 16) I'll try and get a better description tomorrow.
New parts that have been replaced in the past Year to 6 months.
LCA's - Inner Tie Rods - Outer Tie Rods - Wheel Bearings - Moog Springs - NOS Shocks - 3rd Gen SubFrame Bushings
Thanks
Thanks
