Steering belt making noise. Help!
carlsho
Montreal
I just did a 60k service on my car. Not many people know about sho's here in Montreal, so I did it myself. After doing a bicep workout to take off the crankshaft pulley bolt, getting to the plugs and that crankshaft sensor all is good. My only and hopefully last problem is when I turn the steering wheel completely clockwise or counter and give a bit of gas the belt makes a lot of noise. Steering fluids are fine, belts are fine. Could it be that the belt (smaller waterpump and steering belt) is too tight or too loose? Help please.
Slo-Sho
It wasn't me!
Crossroads, CNY
The belt is most likely too loose. Pick any path between point A and point B which has the longest distance. There should be about 3/4" deflection in the longest path. Good luck, and congratulations on doing the 60k yourself. You could've loosened the crank pulley bolt by resting a breaker bar on the subframe and glitching the starter very quickly, works everytime! thumbs_u
