Ok I have a few questions... 95 MTX
I just replaced the Cam Position Sensor and the car runs good except it still suffers from hard starts. Almost always starts the second try, sometimes it takes a third. And when I use the A/C it surges horribly and has immense trouble idling and sometimes stalls. Also, I cleaned the IAC thingy and switched the MAF with a known good one.
Is the hard starting and idle related?
Sometimes (when it idles normally) the oil light will flicker. I want to hook up a temporary oil pressure guage, is there any easy place to do this or is the only spot the one on the back of the engine?
My last question is that the clutch pedal is loose. I can lift it up with my toe. The previous owner had Ford put in a clutch last year. What can I do to fix this?
Also where can I get new intake bolts? The 10mm ones. Whoever took the intake off that time really messed them up.
Sorry so long, but any help is appreciated.
EDIT: No codes. Are all the Cam Sensors the same?
My old one part# started E9SE and the new is E9DE. The rest of the number was the same.
<small>[ August 25, 2003, 05:17 PM: Message edited by: oh_SHO ]</small>
