So I go to crank my car to start it, she sounds like shes cranking REALLLLLLLY slow (like one full crank every 3 seconds) she wouldn't turn over, try it again same thing but I somehow managed to get her running and drive er home. I get it onto the garage and put a voltmeter on the battery, I get no less than like 10.6 while cranking and around 12.9ish while the car is off and around 13.9ish while running (not the alt). I put one lead to ground and the other to the large power wire on the starter and got about 9.3ish, so that should be good. How would I for sure diagnose this as a starter? If I bench tested it, would I know for sure? And are they a pain to pull out? The car is a 93 3.0 MTX. Thanks a ton!
