Starter
ranger690
Wisconsin
So my starter has been out for a week now and I have one on the way but I went to take off the old one this morning. I was wondering how many bolts is there to take out ( so far I only see one) and then there is the one on top of it that has the ground wire in the middle of it that. My problem is that I snapped the connector in the middle that hold the ground. So I have to put another connector on there.
I am just wondering if there is any other bolts hidden that will prevent me from getting the starter off.
ranger690
Wisconsin
where is the other bolt 1 I got off was on the front of the starter below it, and i think I got the stud bolt( probably where I broke off the connector) Where isa the other is it hidden and how hard to get to.
Thanks,
Kyle
badcamelot
Utah
there are two bolts. The stud bolt (that holds the connector) is on the front. Then there is another bolt lower and behind. You will need a deep well socket 1/2" or 13mm for the stud bolt and the same size albiet not deep well for the bolt on the back. the back one is easy to get to, the stud one is a bit more difficult. But as starters go this isnt that hard.
Good luck.
