Starter Dead Spot
NJSHO
Clean Your Shorts!
NJ
It seems that I have a dead spot on my starter. Most time it turns over fine, but on occasion it'll spin, struggle, stop, stop, stop, spin, start. What would cause a dead spot on the starter, brushes, dirty comm.? Can I reman the starter myself?
Eliw
Brooklyn NY
I had the same problem. I dealt with it as long as it took to get a reman. Replaced the starter and whammo! No more bad starts.
khanartist
oldtimer....
Windsor, ON, CA
Could be the battery not getting enough juice to the starter. Loose/corroded cables also. Maybe a tooth in the flywheel?
Reman-ing your own starter isn't really worth it, you can pick a rebuilt one up from any auto parts store for fairly cheap and it will have a warranty.
Worn brushes are the problem. Either that or an accumulation of brush dust that is preventing good contact. Or a broken brush spring.
Eliw
Brooklyn NY
When Mine went bad I was hoping it wasnt the flywheel. It wasnt. Turns out though the starter probably went bad after I had an issue with a battery that had a bad cell and that was only charging to less than 10 volts. Replaced that with an Optima yellow top and spent like $50 for a reman starter. Not bad considering its one of the easier jobs to do on the SHO. Now, the car starts on a dime. Or maybe a nickel.
