starter bolts
Dr_Thompson
CT
this is an odd request but could someone describe the bolts that hold the starter into place, they got lost in a pile of other bolts. are both of them the same size?thanks
Cobraii976
I am an idiot
Well on my 90 the top is a 13mm hex head about 1.5 long. The bottom is a 13mm nut on stud with a 15mm nut on top of that to hold the wiring. I would guess about 1.5 long into the bell and another 1 above the nut. Hope this helps.
Dr_Thompson
CT
yes this does help, thanks. another question, the two bolts that hold the oil pan and tranny together, there black and about 1.5 inches correct?
Dr_Thompson
CT
cool, one more question. on the bolt that holds the wireing for the starter, is there a nut that goes on the part that threades through the tranny. Theres a 13mm nut on the bolt before the wireing and a 15 mm that goes over it but once i thread it threw the tranny there dosnt seem to be room for another bolt on the end. Is it supposed to lock into place or am i useing the wrong bolt.
K-Dawg
Treasure Coast, FL
On the left are the bolts that connect the oilpan to the trans case. On the right are the bellhousing to starter bolts and the 15mm nut. Hope this helps.
