Starter #4???
coldsho
Chalkboard SHO
algonquin il
when tryin to start the key goes all the way forward n nothin happens,no startin or lights or clicks or anything. i can try it a dozen times n nothin!! back it all the way n try again n it again and it works fine!!!! what i break now??? hope itnot another starter or something around that area
Sounds like the ignition key switch is suspect.
<small>[ October 24, 2002, 02:06 PM: Message edited by: sdpatt ]</small>
Mr Anonymous
Tire Wall
coldsho:
just pulled a 6-3-4 code, what is that??? :confused:
The definition for DTC 634 is: Transmission Range (TR) voltage higher or lower than expected.
This can be a result of the PCM detecting that the TR sensor is out of Self-Test range when the gear selector is in Park, or that the PCM has detected an invalid combination of transmission range switch states. (IOW, the Park/Neutral Postition switch and the MLP (Manual Lever Position) sensors disagree as to where the shift lever is.)
Sounds like you could have a bad MLP sensor on the tranny, a bad PNP sensor, or the shift linkage may just require adjustment.
This could also be the reason you're experiencing starting problems.
coldsho
Chalkboard SHO
algonquin il
when the key turns it seems like everything else works, eletronics n stuff! just no engine!!!
