St Louis SHO
Rollin' coal
I haven't really started digging yet, and have my own theories on this but I figured I'd ask here first. Got it up and running. Change the oil (had 3+ quarts of gasoline in it from them cranking the **** out of it. All because of a ground missing
So anywho, The cooling fan is not coming on when it should. If I unplug the coolant temp sensor it will come on, which tells me the CCRM is working properly. My question is, how do you test the drop resistor? Keep in mind I really havent looked into this yet, So any advice will be taken!
TIA
James :wave:
So anywho, The cooling fan is not coming on when it should. If I unplug the coolant temp sensor it will come on, which tells me the CCRM is working properly. My question is, how do you test the drop resistor? Keep in mind I really havent looked into this yet, So any advice will be taken!TIA
James :wave:
