Marccus
My '89 (302,000 mi) stalls when I take my foot of the throttle and the rpm drop below about 1,000.
I was taking an off ramp after driving 40 mi @ 65 mph, down shifted, then started braking after putting it in neutral, when the car stalled. I tried to make the 90 degree turn at the bottom of the ramp through a yellow and just barely got the car turned by man-handling the steering.
It starts up fine and runs fine, but as soon as I release my foot from the throttle and the rpm start falling it stalls. If I start it up and just keep my foot on the throttle so the engine runs above 1000 rpm, it's fine - until I take my foot off the throttle whereby the rpms drop and it stalls again. :banghd:
I've had a problem with the CEL for about a year when it would intermittantly come on for sometimes several seconds or minutes then go off. If I turned the car off when the check engine light came on, the CEL would be off.
There are no codes so bottom line is I can't trust the CEL. :cuss:
I DID wash the engine compartment yesterday but it ran fine after that and it ran fine all morning during my 40 mi drive to work. I've washed the engine compartment down many times during the 16 years I've had the car, but I'm always careful about keeping water off connections, etc, using baggies. Alll my connections are sealed with adhesive heat shrink tubing and lots of dielectric grease to keep moisture/water out.
I did check the "taughtness" of the throttle cable briefly and it seemed "loose". Could the throttle cable have "slipped" from either end slightly so that when there is no pressure on the pedal, the throttle is "shut" instead of being opened to the idle position?
If so, perhaps I can just adjust the throttle body screw.
Also, does the throttle body cable wear out and need replacing sooner or later or is this a "lifetime" part?
Any ideas?
