Stalling Problems
Her94SHO
Texas
I'd like to start by saying this seems like a great site.
Next, My problem I hope to get help with, my wife's stock '94 automatic stalls at low RPM's. It will not idle in park but will when in gear unless I rev past about 1200 rpm. When I let off the gas it will drop to about 500 RPM rebound slightly then die. When driving it will die when slowing down. I've gotten to the point that I have one foot on the brake and one on the gas to keep the revs up. It seems to do fine on the open road and doesn't seem to use more gas on the highway. Any help will be appreciated.
Rio
West Bloomfield, Michigan
I just recently encountered the same problem, but it only happened once. from the responses I got, i'm guessing it is a failing CPS(crank pressure sensor i think). :confused:
projectSHO89
SHOless In St L
This does not sound like a crank sensor. If the crank sensor fails, the engine quits firing.
The IAB is the far more likely suspect, since its job is to control the idle. Clean or replace it, then perform the relearn idle procedure.
Steve
Her94SHO
Texas
I cleaned out the IAB and that cured it. The spring seemed a bit weak so I'll replace it but at least I won't leave break pad schrapnel from my house to the parts store.
Thanks a bunch for the help.
Her94SHO
Texas
OK, all is well except I still have a hyperactive Check Engine Light. I ran diagnostics and came up with a green light with the KOEO but with the KOER I get two codes.
One is 176 which says I am running lean on the RH side. First, which side is that? Second, Does that call for replacement of the O2 sensor or is there usually another problem causing the system to run lean?
The other is 632 which I cannot find any information on.
Can anybody help?
SolidState
No Mo SHO
Toronto, Ontario, Canada
Does the car lurch at all at speed? does it seem to 'slip' a bit?
If so, take it to a tranny shop and have them look at the torque converter.
Just a suggestion.
