Definately a much better shift in my opinion on the 3 & 4 than stock
I agree. But that 1 2 is ruff. Oh well, I ain't worried bout it
Understood, but what is the perceived difference between 2 and 3/4? I doubt I'll load 4, as I don't want to put race gas in the car.Stage 2 has torque management. Stage 3 and 4 have none.
I've had stage 4 on my car for about 2 weeks now. I can easily tell its much harder on my trans than the stage 2 was. My question is how much worse is it for the transmission?
S.
This doesn't seem like a very good idea.or you do as i did with my engine you chain the block to the frame just enought so the engine and tranny mount still give you some rubber feel but you have no more loose on the mount itself will give you a longer living mount
Let me try this again, is there a difference in how hard the car shifts without torque management? I haven't loaded Stage 3 into mine, and am running 2. It shift a bit harder, but I would guess with no torque management it'll shift harder still.
And Livernois "recommends" race gas with Stage 4. I have Two other cars that run on race gas, one 100% of the time...I prefer not to put it in my Taurus, lol.
S.
S.
Thanks...hmmm...I may only use the stage 3 or 4 tunes at the track.Well, the TM cuts out the boost right before the shift to keep a smooth shift. Stage 2 cuts some of the TM out. Stage 3/4 cut all of it out. Stage 2 is only a bit smoother than 3/4 but stage 4 (never used 3) really goes rough on the 1-2 shift and I can feel it.
I know some are running without any race gas and no problems.Ha definately not.
Also, theres a few people including myself running stage 4 without race gas. I think Darrel has run it for months with 93/94 with no problems.
