Chris,
IMO, a motor mount job is definitely no harder than the spring and strut job that you're already thinking of undertaking. For a better idea of what's involved, have a look at the on-line Chilton's reference here:
http://www.autozone.com/servlet/UiB..._us/0900823d/80/0b/f3/a4/0900823d800bf3a4.jsp
Note that even though it is not listed as a step in the listing for the 3.2L, you
may have to drain your radiator and remove the lower radiator hose in order to gain enough clearance to access the front mount on your ATX. I did not go this route when replacing the front mount on my ATX about a month ago and ended up wishing that I had by the time that I was finished. Depending on how cunning and suave you are with your hands, you may not have to go through this extra step; at a minimum, though, I thought I'd give you a little heads-up so there aren't any surprses when you get under there.
As far as mount replacements go, you have three brand options:
- OEM/factory: these mounts, while the most expensive of the bunch, are better than any non-modified aftermarket replacement you can find and are well worth the money. Your best source for these would be
Ford Parts Network, whose catalog listing can be found here:
http://www.parts.com/partlocator/in...=1995&graphicID=JN92127&callout=1&catalogid=2
- Pioneer mounts: available through RockAuto.com and most O'Reilly's parts stores, these mounts should be avoided like the plague. I made the mistake of going with this brand last October when purchasing replacements for all three of my factory-original mounts and ended up with a front mount that had sheared itself completely apart only 10k miles later (details of this will be posted in a seperate thread at some point in the near future). Needless to say, I will not be purchasing another front ATX mount of the Pioneer flavor.
- Anchor mounts: while I do not have any personal experience with these mounts to speak of, I have read of other forum members who have had pretty good success with these mounts on their ATX's. Even so, I would still advise extreme caution with these mounts and recommend that you double-check both their strength and construction before you plop your cash down on the counter to purchase them. Available through RockAuto.com and most AutoZone stores.
I should note that the above is just my two cents based on personal experience. Your (actual) mileage may vary.
