Speedo Problem
ryana83
Nashville, TN , USA
Ever since I purchased my 92, the speedometer hasn't worked. I replaced the lower part of the cable that threads into the transmission and it still didn't work. So i checked and it seems like the male end that goes into the lower cable is cut. Does anyone have a diagram of the speedo cable layout? If not, can anyone tell me where it runs to through the dash. Does it attach to the gauge cluster?
Ryan
socialdeviat
Ca
Is it a MTX or ATX?
on my 94 ATX it runs from the back of the cluster to a joint near the brake cylinder. From there is goes behind the engine to the VSS. The VSS plugs into the governor assembly which bolts onto the tranny.
Easy check is to remove the two cables from one another and spin the upper cable while someone inside checks for playback from the speedo. Should spin in the counter-clockwise direction(if im wrong please correct me). Then spin the other side, if it doesnt spin then your good. You just cancelled out the cables, the cluster, and the gear on the VSS. Now you can pull the Governor (IF SO EQUIPPED) it has two 8mm (5/16") bolts. Has a PIA cover to remove. Easiest to go from the top with the intake off, but you can also go from the bottom.
Remove it. There should be two gears mounted on a shaft and the cover which comes out. The smaller gear should be straight. If it is in any way concaved, If you were to look at it sideways the gear should look like a rectangle. If the sides are concaved you solved your problem. That part costs about $45-50 from the dealer. Worst case scenario is the gear in the tranny and That bad boy if done at the factory or rebuilder would set u back about $450 Easy.
Good Luck. If I can find photos I will post them. And again if its a MTX I dunno exactly if the above mentioned checks would be the same. Someone else might be able to help.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
I'd like to know too. I just snapped mine up front yesterday. :( Maybe cause I spun it a little too fast messing with that mustang yesterday. :) Was the lower 1/2 easy to do? I havent really even looked at it to be honest. I figured I'd be taking the cluster out.
Or where are you getting parts from would be a good ? too.
ryana83
Nashville, TN , USA
It is a MTX car. I have been on a business trip to Ohio for a week, so I haven't been able to work on it. The lower cable is super easy, but I have never done the upper.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Well the upper is the one I have thats smoked, but I can't find one at AZ. All they have is the center cable itself, and its a cut to length thing. My sheild is crusty and partially MIA, so I need the whole assembelly. is this a WTB thing? Where are you guys getting these?
