Speedo not working
SHOSIG
Is that right!
OH you didn't know
My speedometer quit working, but my cruise control still works. Could this be the cable itself or the speed sensor? Any help would be appreciated! Thanks!
Ishodu
It will be the speedo cable. Either the upper one or the lower one. You can easly take them apart at the rear of the TB down low. You can easly see the cable coming up and going into the fireway. Take it apart there and turn the upper section and get a buddy to sit in the car and see if the speedo moves if it does you may need a lower section. If not well the problem it either the upper cable or the head itself.
SHOSIG
Is that right!
OH you didn't know
spun the lower--nothing---disconnected the lower from upper and pulled on cable from upper.....three inch section of cable came out...yep it is the cable.
