speed sencor switch
svt cobra brett
SHO LOVER
FLORIDA
speed sensor switch
can anybody tell me where the speed sensor switch is on a 96-99 sho..i have to repl mine and can't find it...please help me
thanks brett :thumb:
svt cobra brett
SHO LOVER
FLORIDA
Mr Anonymous said:
Isn't one. PCM and speedo get their speed data from the ABS system.
yes there is one i have it in my hand pt# E9LZ-9E731-A SENSOR ASY
THIS WAS ORDERD FROM FORD USING MY VIN# THE REASON I BOUGHT THIS IS BECAUSE MY TRANNY IS SHIFTING FROM 1-2-1-2 ND GEAR AND THE TRANS SHOP TOLD ME TO ORDER THAT PLUS THE SPEEDO IS JUMPING
Mr Anonymous
Tire Wall
I'd love to see a pic since I've worked on 300 or so V8 SHO's, put in a couple dozen trannys, chopped up a whole bunch more, and have never seen one.
I wonder if someone put a Duratec tranny in there, but even if so there wouldn't be a connector on the stock harness for it.
svt cobra brett
SHO LOVER
FLORIDA
I Know But Its There And I Have The Switch?? THIS IS A AX4N TRANS.TAKE THAT PART NUMBER AND CALL FORD...HERE IS THE VIN# OF MY CAR--1FALP54N2VA261956 FORD WILL NEED THAT AND SEE FOR YOUR SELF
:thumb:
BRETT
If you have a VSS in the tranny then you have a SLO tranny. All V8 SHOs get the speedo info from the ABS computer.
Speedometer
The speedometer operates in the following manner:
The speedometer (17255) receives a speed/distance signal from the transaxle-mounted vehicle speed sensor (VSS) (9E731) (except 3.4L SHO).
On SHO vehicles the speed/distance signal is provided by the anti-lock brake control module (2B373).
Speedometer displays speed in km/h and MPH.
The speedometer for 3.4L SHO is limited to 240 Km/h (150 mph).
Mr Anonymous
Tire Wall
:thumb:
BRETT
Let's see a pic (of the VSS installed in your tranny).
The VIN number is meaningless, and actually that part number does not cross to any Taurus or Sable apps in MicroCat anyway.
Mr. SHO
Philadelphia
I just have to laugh here... :rofl: someone is disputing two people who know more about the SHO than most people can fathom. And to back up this dispute, he's citing FORD. :nut:
Welcome to the world of the SHO. Forget everything that Ford ever told you and you might learn a thing or two. :thumb:
svt cobra brett
SHO LOVER
FLORIDA
well i guess you guys are wright it was not on the tranny so i have to take it to the trans shop on monday to get it scanned to see why this is doing this..i was going with the ford dealer was telling me and the trans shop as well..i guess that sho is a breed of it's own..any more ideas
thanks brett
svt cobra brett
SHO LOVER
FLORIDA
never seen a light but the trans shifts back and fourth if i put it in drive...i can shift it by hand and it grabs the gears fine with no slip at all ..the issue with it is that when i take off in drive it will take off in 2nd and sometimes 1st then it shifts back and forth several times and when it does that the speedo goes crazy...i can be going about 70mph and give a littlt gas and the speedo goes to 0...please help me find the problem it's getting real old to have to shift this sho every time i go to take off..plus by the way thanks for the help on the cooling tank issue the new one you told me to buy works perfact ..you do know your sho's :thumb:
thanks brett
Ian Macoomb
Ottawa, Ontario, Canada
When I put new knuckles on I couldn't get the old ABS sensors off the old knuckles. I got some new ones from Kirk but before that I drove around with no front sensors. The tranny didn't know what to do. It was seriously messed up.
Mr Anonymous
Tire Wall
do you think that the trans is shifting funny because of the speedo issue
brett
Yes, the PCM tells the tranny when to shift based on a number of factors, and speed input is probably the most important. If the speedo isn't getting good data, chances are neither is the PCM.
Check the connection to the ABS computer which is located just forward of the battery tray. It's a 10mm bolt, and I recommend removing the connector and making sure both sides of it are clean -- it's very common for dirt and other contaminates to get into that connector. Usually a good blast of compressed air will clean both sides of the connector.
Short of that, as Ian mentioned it would probably come down to a problem with one of the ABS sensors. Have the codes scanned at AutoZone for free and see if there are any ABS codes.
svt cobra brett
SHO LOVER
FLORIDA
ok ill check the abs computer connection...is this between the battery and the headlight...let me know
thanks brett
If you take the battery out and then remove the battery tray you will see an aluminum thing with a bunch of tubes coming out. It has "SHO ONLY" on it. This is the ABS hardware. The connector is attached.
Twisted99
South East
If the ECM does not see a signal say around 115 mph as happens on the 98's, what happens? Does the tranny and engine self destruct?
SHO#7
Cincinnati
The car works just like normal, except for no speedometer reading. And FYI in my 98, I keep the exciter rings and speed sensors clean. I have a speedometer reading up to 130.
Mike
