svt cobra brett
SHO LOVER
Mr Anonymous said:Yes, the PCM tells the tranny when to shift based on a number of factors, and speed input is probably the most important. If the speedo isn't getting good data, chances are neither is the PCM.
Check the connection to the ABS computer which is located just forward of the battery tray. It's a 10mm bolt, and I recommend removing the connector and making sure both sides of it are clean -- it's very common for dirt and other contaminates to get into that connector. Usually a good blast of compressed air will clean both sides of the connector.
Short of that, as Ian mentioned it would probably come down to a problem with one of the ABS sensors. Have the codes scanned at AutoZone for free and see if there are any ABS codes.
ok i went and took out the batt tray and removed the connector and cleaned it real good on both sides with compressed air at our shop and put it back together and while i was there i cleand up all around the battery area and scrubed the tray and put it all back installed battery and cleaned the batt poast and cables and still i have the same problem.im going to the trans shop that a buddy of mine ownes and they will run the codes for free...so ill let you know what happend monday night
thanks brett
abs codes came up clear
