Speed/Rev Limiter - Disable?
David Daly
Commerce Township, MI
I have a 2015 Non-PP SHO, and would simply like to disable the speed limiter. Do want to put a tune into it, just disable the dam* limiter. TIA
I don't know if you can remove the speed limit with Forscan, but when you have it tuned most tuners can disable it.
THis. I also don't know how much is doable with forscan but this is an electronically limited vehicle and that is the only solution.
Bluezone
Ont, Canada
I'm not sure if you can deactivate the speed limit or not. I seem to recall hearing they can raise it so that it's not a problem. Might be wrong though.
redmtsho
Billings montana
So if you go to pcm on forscan and open it up. Thats where you can disable the speed limiter. I can also drop the spreed sheet for forscan for the taurus. You can change your steering to the pp settings as well and do a bunch of other cool things with it.
Brad kirk
