speaker probs.
95IVSHO
workin with a 95 SHO.
left rear speaker started cracklin and getting staticy real bad so i thought it was goin bad so i disconnected it, then a few weeks went by and now the drivers door is doing the same thing. so i went ahead and replaced the front set and the rear set and i did not fix the problem. need some help please???????
CerberuS
300 HP N/A SHO
Granby, QC, Canada
I had the same issue with a CDR burned CD , and it was fine with a regular CD or FM stereo.
Does it sounds ok with a real CD?
ViPER1313
Ijamsville, MD
The amp in the trunk is probably on its way out. Does the crackling go away when you put the volume to a higher or lower level? Does the stereo "pop" when you increase or decrease the volume?
95IVSHO
when i turn it up its still there alittle bit but doesnt get any louder.
95IVSHO
is there anyway i can just shut down the factory amps and just use the head unit itself. it puts out enough power for the speakers that are in there????
0V3RC10CK3D
Washington
From my understanding thats what the second connector behind your deck is for, one is amped and one is straight to the speakers, you can just switch to the others but don't leave the amps connected.
carterh
Calgary Alberta
95IVSHO said:
it makes them noises all the time any cds, radio, xm doesnt matter.
I spotted the problem! No one could possibly expect a speaker handle that XM crap!! Get SIRIUS while you still can! :)
95IVSHO
hey hey i like my xm i believe sirius was having trouble staying alive if im correct.
95IVSHO
i found that connector that a few of you said was there that i could bypass the factory amps but there is a problem... it does not fit the plug for the install kit to the headunit.???????
