SPC - Camber and Caster Bolts - should work on 2010-2019 H&R
kryptto
South East, Florida
I saw a lot of going back and forth from separate posts in these threads about caster and camber bolts. So if you are using H&R springs and looking for adjustable bolts for front and rear alignment, most bolts are "fixed" and match OEM tolerances for stock alignment specs:
SPC makes adjustable front and rear bolts - called Summit Racing they called SPC - these are made to go below or above OEM specs.
SPC Performance Wheel Alignment Parts 84135 KIT - comes with x2
Part Number: SPS-84135
±1.75° of camber adjustment
SPC Performance Rear Camber and Toe Adjustment Kits 84130 - comes 1 bolt - need QTY 2
Part Number: SPS-84130
Rear Camber Degree of Correction 1: -0.75
hosbaldosho
