Camber Bolts and H&R Springs
Iqoniq
Atlanta, GA
Did anyone need SPC Camber Bolts when they installed their H&Rs? It suggests it might be needed for alignment, but given that there's quite a few of you here who've done the install, I figured I'd ask first, since I've seen no mention of them previously here on the forum.
yaycandy
Aerospace Engineer
Hanover, PA
I did not. Shop told me if its done right it dosnt need them. I bought them and they didnt use them.
Theres my stock springs and bolts they didnt use.
16505C62 270B 43D8 8882 06BB27B1BFBA
fordfanstan
CA
I can't say whether I actually needed them or not. I read I did, so I bought them and installed them, then drove to the alignment shop. Just so happens no alignment adjustments were needed on the rear as everything was in spec with the SPC camber bolts installed on rear.
If you do buy them, make sure you get the right SPC part number #84130. In old threads there was another part number (I wont mention here to eliminate confusion) that people used. I ordered the wrong ones first.
SHOthyme
MN
2018 non-pp - didn't need them, brought it in to get aligned and it wasn't far off, and they were able to get it into spec.
yaycandy
Aerospace Engineer
Hanover, PA
I ordered 81280, maybe mine are wrong.
fordfanstan
CA
This is the part number I bought first time around. I never installed them. From older threads it appears they work, but are not actually the correct bolts for our application. So I bought the 84130 instead and used them.
Iqoniq
Atlanta, GA
Annnd ... they arrived this morning. My next two weekends are full now: tap the PTU first, install my H&Rs second. I might try my catch-can one of these weekends, too ... depends on how much time it takes me to do the other stuff.
Thanks, Ortiz.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
Thanks, Ortiz.
Sure thing!
