Spark Plug O ring specs
beaudeen
BEAUDEEN
Shannonville, Ontario
G'day all...anyone out there have the specs for the spark plug well O rings..I'm sure I can find something at work that will do the job..I have a new set of valve cover seals, but not the plug well seals..I'm sure an aircraft o ring can be used...thanks..!!
beaudeen
BEAUDEEN
Just thought i'd ask..thought they were just an o ring...can you purchase just the plug well seals anywhere..location appreciated...thanks much..!!
LJRuddy
Pop lock n drop
Poaceae fields
I am sure that you can buy JUST the o rings... I have not been able to find just the rings. Every store that carried the valve cover gaskets, came with the cover gaskets as well...
A Ford dealership sold the set for around 140 bucks. They are not cheap to replace and they are hard to find. I bought the last set from Ford in the KC area. :p
projectSHO89
SHOless In St L
The VC gasket set that includes the seals is a common FelPro item available from any parts store usually a special order item.
The individual tube seals were available from Ford, but they were expensive. You might still find them in stock at a dealer, but the odds are low.
Steve
92inPA
s.e. PA
Go to your local parts store and order a FelPro VS50378R. That will fix you up.
