Sound Familiar To anyone? (VID)
shoon
cliTaurus
Dawson Creek, BC
http://smg.photobucket.com/albums/v118/MnKyOfHaTe/?action=view&current=VIDEO0004.mp4
As for the dirty engine bay.. I know haven't had the time to clean the car in a while.
IMAG0325
working 12 hour 24day shifts.. which is also the reason I am too lazy to pull the belts off to see if that eliminates the noise.
I was hoping someone might recognize it and share their experience :)
Edit: Pulled alternator belt off.. everything spins smoothly; no free-play. Started it up without belt, noise is still there.
think that leaves:
PS pump, water pump, idler, or valvetrain noise
holy dirty cars, Batman!
I think it will turn out to be a tensioner bearing, and my guess is the timing belt tensioner, but you'll have to pull it apart to find out.
93rev2sev
Hockeytown
I think i hear a very loose valvetrain and a squeek that will probably end up being the water pump.
shoon
cliTaurus
Dawson Creek, BC
thanks!
new dayco tensioner and belt few thousand km's ago, but will check it out. as far as the valvetrain i just did valve lash in feb; everything was adjusted to the tight side. noise seems most noticeable when hot. also, wp was done at same time as tensioner, no more than 20,000kms ago. looks like ill have to tear into it on days off.
thanks again
shobroooo
