WARNING TO ALL SHO OWNERS
Garichette
If you have a no start situation and you believe it has to do with the ccrm (constant controle relay modual) on the front top radiator mount. Avoid major parts stores, In my experience with O'reilly's I was sold the wrong one not once but twice. I had not discovered this until I had replaced the fuel pump, ECU, and pulled the entire harness to check for shorts that I didn't have.:smash: After three months and a bunch of wasted money I was pulling the belts off the to change the Crankshaft Position Sensor and started to suspect it was the ccrm and after checking BWDs website (ccrm manufacturer) they don"t even make them for the SHO. So I got one from shosource.com showed up in three days, slapped the belts back on plugged her in and stared FIRST TRY.
so just make sure you get the right one and you can't always trust the bigger parts places that one, sell people the wrong parts but also have a policy against returing electronics after they have been installed is not cool. but they were nice enough to refund me for the second one. just thought I would share this to maybe save someone from this nightmare I had to deal with.
The above issue applies not only to ccrm, but all parts. Many of the parts stores do not accurately differentiate between 3.0 vulcan and 3.0 SHO, so if you are not sure, ask the parts counter guy to look up the part number for the 3.0 vulcan part. If he says it is the same, then you know it is not the right part for your SHO.
hosbaldosho
