Something is wrong w/my door handle
strykr14
Michigan
As I was getting out of my 95 today I heard a little click when I opened the door and now the inner door handle is loose. It still opens the door but there is no tension on it until it does. Anyone have any idea what this could be?
shocrates
will never know
NJ
The spring in the door handle is broken. It's a common problem.
To fix it get another handle from a junkyard or a parts car that has a functioning spring. A handle from the front or back will work as long as it's from the same side of the car. Remove the door panel, remove a screw or two, and unhook the handle from the actuating rod.
strykr14
Michigan
Just so happens that I have an extra door sitting here for the SHOwagon so I'll be able to grab it from the old SHOwagon door. No difference between the 92 and a 95 I assume?
Shopower400
Atlas
Electric City, NY
Nope!
Make sure you put some oil on the new 1 to extend it's life, and try to be aware of how hard you're pulling on it in the future!;)
I've broken 3!:doh:
