Someone Please Help!!!!!!!!!!!!
crx300x
Great Falls, MT
hello. i have a 1993 SHO with a 3.2L engine. my issue is that i CANNOT GET THE TIMING RIGHT! i have been trying to get the crnkshaft timing gear to line up but i have no timing marks on the bottom half. does anyone know the best way to set the timing for this? any help will be greatly appreciated. thanx
Off Road SHO
Moderator
By bottom half of the engine, do you mean the lower plastic timing cover? That should be removed already. The dimple on the lower timing sprocket that is on the crankshaft, should be pointing at the raised bump on the oil pump that is at about the 5 o'clock position.
The dimples on each cam sprocket should be at the 12 o'clock position and therefore lined up with their corresponding bumps on the timing cover's backing plate.
Tom
Toolman
Boost it!
Grand Lake, Oklahoma, USA
If you already have the lower timing cover on you can still line up the crank pulley marks with the 0' mark on the cover, then line up your cam sprockets. Good to go.
Off Road SHO
Moderator
Toolman said:
TOM! Your buggy ran a 12.48? Sweet!
Yes, and without the nitrous turned on. With the nitrous, she wheelied so high I had to back off untill the front tires came back down. Then I nailed it again and still did a 12.78 at 108. What a rush. Those BF Goodrich knobbies were smokin!
Tom
crx300x
Great Falls, MT
okay i think i got it but i was told to line it up so that the #1 piston is at TDC of the compssion stroke. when i so that, the dimple in the crankshaft timing sprocket lines up to about 12 o'clock (straight up) so now what should i do?
This post describes the methods to check the proper alignment of the timing belt on 3.0L and 3.2L SHO engines for installation of a new or used belt or verifying the alignment of a previously installed belt.
Search keys: timing belt alignment index marks
To check the alignment of the belt after the timing belt covers have been installed and the engine has been run, refer to "Checking Alignment of a Previously Installed Timing Belt."
When replacing a new or used belt on the engine, refer to "Alignment During Initial Timing Belt Installation."
Remove the upper timing belt cover and rotate the crankshaft clockwise until the second, white notch on the crankshaft damper aligns with the "0" mark on the timing tab on the lower timing belt cover (0 degrees BTDC on the #1 cylinder). The first, yellow mark indicates 60 degrees BTDC on the #1 cylinder and is used for setting the belt tension on the 3.0L engine.
The index marks on both camshaft pulleys should be aligned with the index marks on the rear timing belt cover at the 12 o'clock position. See the pictures below of the alignment of the upper marks. If the camshaft pulley index marks are at the 6 o'clock position, rotate the crankshaft one revolution in the clockwise direction and check again.
Refer to the pictures below to install a timing belt in the proper alignment. NOTE: This is the only occasion when the white lines on the timing belt will align with the index marks.
The crankshaft pulley on the 3.2L engine. Note the alignment of the dimple on the pulley tooth with the line on the belt and the raised ridge on the lower timing belt cover boundary wall.
Here is a photo showing the crankshaft alignment on the 3.0L engine.
This is the alignment of the rear bank camshaft sprocket. Note the index marks on the pulley, the white line on the belt and the raised ridge on the metal timing belt cover behind the sprocket.
This is the alignment of the front bank camshaft sprocket. Note the index marks on the pulley, the white line on the belt and the raised ridge on the metal timing belt cover behind the sprocket.
Mr Anonymous
Tire Wall
Put the crank bolt in to rotate the crank until the dimple one the timing sprocket lines up with the corresponding ridge cast into the oil pump at about 5 o'clock. Then follow the instructions sdpatt covered above.
