ultimatesho
registers 163k, black on black full leather, keyless, all power, and moon roof
was daily driven till i got another car after the fuel pump went out, will replace with new assembly if sold...wouldnt hesitate to drive it anywere
for cosmetics she has......17x7 Enkei CDR9's, CincySHO Cowl, Custom SHO badges courtesy of Will Lewis @ wclewis.com, SHOForum decals on the rear 1/4 windows, Clear corners, JVC head unit, Matte metal gauge brezel, Black out tail lights, Shaved trunk
maintenance........Bran new clutch setup, Rod Bearings, Motorcraft plugs, Blue Taylor Thundervolt 8.2mm wires, Accel Super Coil, and K&N panel filter all about 20k ago......bran new brakes all around (rotors and pads), 96 upgrade up front (new rotors, pads, and calipers), heavy duty rear sway bar endlinks with poly bushings, both axles, thermostat, NUMEROUS hoses all over, both outer tie rod ends, rear strut mounts and rear Monroe struts all within the last 10k...........starter and alternator within 2k....new heater core, front main seal and reinforced mm's, bran new brake lines, CPS, TPS, 2 new Nexxen tires up front, new fuel pump assembly
have the carfax on hand for it......only issue is it reads unknown mileage, not really sure if it was a gauge replacement or rollback
The bad
driver rear door handle is broke off
apparently somthing broke inside the pass. door handle, door opens fine from inside but not outside
both rear tires shot......will replace if sold in running condition
interior is starting to show its age
could use a new paint job
any questions just ask.....im asking $2,000 or the first reasonable offer with new fuel pump assembly or $1,500 as it sits....if its not sold soon itll b parted and crushed, have no use for it anymore and tired of looking at it
Josh 731-438-2401 [email protected]
...i RARELY ever get on here anymore so eather txt or call or email me
The bad
