alright so i have had this ticking noise for a while and i automatically assumed it was valve tap. then i read a post last night about a ticking noise and people said it could be timing tensioner or cam chain tensioner and that u can listen with a screwdriver. now i dont know how to listen to things with a screwdriver but i can probably guess how to. but just to rule out possibilities the noise goes away when i disengage the clutch (push pedal in). also, tap speeds up in higher rpms and often goes away as rpms get high enough. any info would be great. thanks
