ThatShoGuy
well should i start to worry... the "death light" is on oil light flicks at 5-600 rpm(idle). but no motor knockin signs?
opinions????
opinions????
I've never owned a V8.. but isnt 500-600 a little low? If I get my V-6 that low, it'll probally come on too.
It's stupid to assume a 9K mile new shortblock can't have problems. Especially since you still installed used heads and a used oil pump, right? And you rebuilt it yourself, right? Just because the block was new doesn't magically make everything else new.Remenber ITS a NOS short block with 9,000miles oil never seen over 2000miles each time changed, and oil hasnt had any signs of metal yet the new oil has maybe 600miles on it.
sad thing is i cant park it, its my only ride.........
My notebook with the shop manuals on it is down, but IIRC you should see about 10-12psi at hot idle.i need to just break out a real gauge and check it. whats the spec of the pressure anyone know...
The more cylinders you have to help take evenly space the pulses around the crank can allow you to let the motor idle much slower.I've never owned a V8.. but isnt 500-600 a little low? If I get my V-6 that low, it'll probally come on too.
What are you going to do for your "only ride" if you blow up your motor? Do they not have taxis or buses where you live to get around? It amazes me when people say they have no alternative transportation. I've yet to visit a city or town with a population of more than 5000 people that didn't at least have one if not more taxi companies. A $10 cab ride for a day or two can be a lot cheaper than the alternative!
What oil and filter are you using? 20-45 @ 1500 rpm with hot oil is the factory spec. The oil light probably comes on around 6-8 psi.
