Smell of oil
gaboubi97
Quebec
Hey guys, for quite sometime when my car is hot and I am downshifting the car is making some smoke. It smell like oil. It does'nt smoke at idle or when I start the car only when im in sport mode and it downshift to come at a the stop. I think my turbo might be going bad but I want your opinion.
year, mileage, maintenance history? if you suspect the turbo check all the hoses especially at the clamps. the pcv valve is another popular source of oil based issues.
gaboubi97
Quebec
It's a 2014 with 75k mile and I always change my oil at 3k mile max. I have a upr dual catch can and it almost never got oil in it. The rear turbo have a little bit of oil on it seem to be coming from the piping.
BradM
Pull the intake hose off the throttle body and inspect for oil residue. If there is, it could be blowby from the bypass valves (I know you have dual catch cans) or a turbo is leaking. A turbo leak could worn seal ring(s) or excessive crankcase pressure pushing oil past the turbo seal rings. On my car, I measured 2.5psi of crankcase pressure during boost. If you look at the PCV connector on the valve cover of Bank 2, you'll see that unlike the Bank 1 connector, it has a tiny passage. This limits flow and allows crankcase pressure to build. I'm not sure why it's designed that way and I vented my crankcase through the oil cap to reduce the pressure. This can throw a code for "PCV disconnected".
gaboubi97
Quebec
How do you measure crankcase pressure ? And my catch can is design to vent by the oil cap if thats what you mean ? There was a little bit of oil residue on the thottlebody.
1000005276
did you install the sho specific application? if so i would talk with upr directly. how much oil you catch is a function of proper connections of course but also the location of the can itself. the lower and cooler the better. you will see more results in the winter time as conditions are ripe.
would also advise making sure the hoses are fuel/oil rated. many have had a problem even with hoses supplied by the catch can manufacturer.
@kryptto you have a upr setup correct?
  • 10-14-taurus-3-5-sho-ecoboost-dual-valve-catch-can-css-plug-n-play-4__50737.jpg
  • 10-14-taurus-3-5-sho-ecoboost-dual-valve-catch-can-css-plug-n-play-1__47222.jpg
BradM
I modified an oil cap to run a hose and gauge for diagnostics. With the OEM PCV system in place, I measure 2.5psi under boost.
gaboubi97
Quebec
I'm pretty sur my catch can is correctly connected. Maybe I should try to put the oem pcv system back on the car ? And I'm gonna try that to measure the crankcase pressure. Thx guys in advance
kryptto
South East, Florida
Yes sorry been dealing with this sheet in airports:
Here are my photos, https://photos.app.goo.gl/PYiuL7BeGHCJbVabA
I have the same model year, so photos should natch, the 2015+ have a different strut tower config as a fyi.
If there is any questions about parts and install contact Steve Buscius directly.
BradM
I'm running ~19psi of boost with peaks of 21psi. If you are stock, your crankcase pressure may be way lower.
gaboubi97
Quebec
Sorry guys I was on vacation and didnt have time for the car. I took photo of how my catch can is connected and seem to be similar to your photos . I've seen guys saying that it could be that the turbo oil filter might get clogged. Do you think I should clean them ? I didnt have time to check the cranckcase pressure either.20240723 140346
20240723 140353
20240723 14040220240723 14041120240723 140507
20240723 140343
kryptto
South East, Florida
Sorry guys I was on vacation and didnt have time for the car. I took photo of how my catch can is connected and seem to be similar to your photos . I've seen guys saying that it could be that the turbo oil filter might get clogged. Do you think I should clean them ? I didnt have time to check the cranckcase pressure either.View attachment 91322
View attachment 91324View attachment 91325View attachment 91326
That looks like mine for sure - you replace the filters in the turbo lines btw. They can be a pita to get out as with anything right engine turbo.
BradM
No need to replace the turbo oil line filters (screens). They come out easily and just squirt them with brake clean. But if they were clogged, you'd be burning up your turbos. My screens were perfectly clean with 12,000+ running hours on my engine.
gaboubi97
Quebec
So it look like my turbo might start to be bad ? Looking at the oil level and it's still good doesn't seem to drop.
gaboubi97
Quebec
At idle when the car did run during the day and now is almost cold it might smoke white/blue but rarely and when I downshift in sport mode it smoke too.
4SHOx
