Small parking light replacement?
Eric Hardy
I noticed this morning the small parking light bulb burned out. I'm pretty sure it's a parking light bulb. Does anyone know how to change that bulb because it doesn't look easy.
2011TAURUSSEL
2014 SHO LMS Stage 1 V10
DFW Metroplex, USA
I was going to say remove air filter housing but not that easy. When I work with my LED DRL's I will see if I find a better way to access.
Pintony
40 miles N.E. of St; Louis
Hello Eric,
In an earlier thread most members said remove the inner splash shield in that corner... I think???
Oh... And have really tiny hands!!!!
The bulbs Ford use nowdays must be substandard....
I gotta do this too...
Eric Hardy
I think it's a little harder then that but I'm not sure lol. I was thinking about ordering the drive bright led's and removing the bumper. It's always good to learn.
Eric Hardy
Hello Eric,
I saw that I was reading it but I don't have tiny hands haha. You need a chick for that job. They make everything difficult plus I don't even see how to get to it. It's that 194 bulb I'm pretty sure that's what it is.
Here are the 13 SHO bulb specs:
BULB SPECIFICATION CHART
Replacement bulbs are specified in the chart below. Headlamp bulbs
must be marked with an authorized “D.O.T.” for North America and an
“E” for Europe to ensure lamp performance, light brightness and pattern
and safe visibility. The correct bulbs will not damage the lamp assembly
or void the lamp assembly warranty and will provide quality bulb burn
time.
Function Number of bulbs Trade number
Low series low/high beam headlamp 2 HIR2
* High series Low/high beam headlamp (HID) 2 D3S
Front park/turn lamp (amber) 2 3457AK
Sidemarker lamp (front) 2 194NA
* Sidemarker lamp (rear) 2 LED
* Tail/brake lamp 2 LED
* Rear turn lamp 2 LED
Backup lamp 2 921
License plate lamp 2 C5W
* High-mount brake lamp 1 LED
* Supplemental park lamp 2 LED
Map lamp 2 W5WL
Dome/reading lamps 2 W5WL
All replacement bulbs are clear in color except where noted.
To replace all instrument panel lights - see your authorized dealer.
* To replace these lights - see your authorized dealer.
Front parking lamp/turn signal/sidemarker bulbs:
1. Make sure headlamp switch is in the off position, then open the hood.
2. Reach in behind the headlamp assembly to access the bulb sockets and connectors.
3. Rotate the bulb socket counterclockwise and remove from the lamp assembly.
4. Carefully pull the bulb out of the socket and push in the new bulb.
Install the new bulbs in reverse order from the steps above.
2011TAURUSSEL
DFW Metroplex, USA
I removed the Inner fender splash shield and couldn't see a easy way for bulb replacement.
Eric: The LED DRL kit DOES NOT require the bumper removal, lower forward splash shield, Drivers wheel, inner splash shield at very minimum drivers tire. Passengers side, the Intercooler charge tube should about do it. If you decide to get the Daytime Bright kit let me know I have some photos and some "Lessons Learned" and install tips that are as they say....."Clear as Mud" Dan Smith was helpful and courteous with my calls. Some of the tips I give credit to Greg Baxter the path finder of this project.
