fastsho92
SHO POWER!!!
ok this is what happen. my car has not been ran it about 3 months. I took it apart because it was running very un smooth and felt like it had no torque. so i took it apart to chage out the knock sensor because my brother a ford mechanic told me that was the problem. so i took off the intake mani and fuel to get to it. then i put it all back together and that is when the problems started. it leaked fuel from the fuel rail badly, so i got a new one off ebay and put it on. everything was A Okay
because it didn't leak fuel. but when i went to start it well it didn't.
so after some help from you guys i found out that my new plug wires were not right. after putting them in the right spot i started the car and at WOT it would only sit a about 800 RPM then it would stall so i started it back up a few times thinking it was just some crap that needed to be ran through the motor. i guess i was right because after about 3-5 times of doin this it started up fine and when through the rev rang nicely. when i went to move it, I let off the clutch at about 2000 rpm the rpm dipped so i gave it more gave but it didn't seem to want to go. like it had 0 torque or somthing. i drove it about 1/4 and when i gunned it it would hardly move until it hit a torque curve at about 3500rpm. from there it reved up nicly but under that it felt really sluggish. The car has new plugs and wires. also has a new IAC. Even no the plugs are new they might be fauling because of all the fuel that was ran through the motor when the plugs were not right. so for how cheap they are i think i am just gona get a set and see what happens. also wanted to no if there was not a 60K done on a car with 120k if that would cause problems like this. im not sure if there was a 60k done on the car or not. but do you think this could also be a problem?? give me your opion and please tell me what you think could cause this
