SHOracer14
Me-0 Diffs-6
Ok, I am officially stumped on this car. By far the slowest SHO I have owned... it just doesn't seem to have the pull my other cars had. Everything has been done on this car (it has a well documented history @ 163k, full 60k done about 2 years ago) so figured some basic cleaning and maintenance was in order. I pulled the intake and cleaned it inside and out, new plugs and new fuel filter with injector cleaner. I also ran the codes and the only two that popped up were primary and secondary fuel pump circuit failures so those must have been stored. Also, the car has a walbro 155 and some sort of factory spec remanned MAF on it. I put everything back together and there was no change. I got to thinking about it and it seriously feels like the SpOUT circuit is open but it does not throw the code and the connections are good. I figured maybe something else is causing the PCM to retard the ignition. I don't have access to a timing light until tomorrow but, what should the car be running at idle?? I threw it on the scanner at work and the computer told me to check the SpOUT connections and make sure the car is running at 20 degrees. Is that correct timing at idle? My other question is this. I always thought the SpOUT jumpers were just a jumper that only closed the circuit when installed. Are they actually a resistor and possible be bad? Maybe not bad enough to throw a CE but bad enough to have timing slightly reduced? I have no clue, the car starts, runs and idles smooth as heck... it just doesn't seem to have the power. My next step after checking the timing is a compression test and changing that MAF to a factory unit. My only other thought is possibly a clogged cat. Any other ideas? All help is appreciated.
EDIT- Put a factory MAF in the car with no change.
forgot about that..
