Sloppy Shifter
frobie15
Bimmer guy
California
Like the title says, I've got a shift **** and shaft that rotates slightly in both directions. The whole shaft moves, not just the ****. Anyone have any knowledge on how to easily fix it? Any thoughts?
NebraskaSHO
Harumph!
Omaha
I'd just find another from the Junkyard from a console car or from eBay. Look for midnightauto to see if he has anything.
midnightauto
THE CHOP SHOP
Michigan
slide the plastic cover down the shaft below the handle. That will expose the 2 screws you need to tighten
midnightauto
THE CHOP SHOP
Michigan
Ray, I see no way to slide the plastic down the shaft. Could you be more specific, please?
pax, smn
you need to use a little force. The tube clips to the bottom of the shifter handle. If that does not tighten up the problem get a new shifter and tell your girfriend/wife to stay on her side of the car.
stephen newberg
Ladysmith, BC, Canada
OK, I will try that fix, but no way I am telling Jeannie to break a habit of 35+ years...
pax, smn
